Scan to email
  • JVC
    • Jun 2011
    • 151
    Scan to email
    I have a customer with a Konica Minolta Bizhub c654 that I can not able to get scan to email working. I am using the same settings that work on the c654e machines. Can anyone tell me what the differences are between the 654 and 654e? Is there any chance I am missing something simple?
    Thank you in advance for any help you can provide.
    Joe
  • kingarthur
    • 1387
    Re: Scan to email
    How are you scanning, are you using gmail....in which case, you're going to have fun, it'll need a special FW, which is "fun"....
      Re: Scan to email
      Joe
      ummm a little more info please?
      is it connecting via IP ... are all the server names correct?
      what errors/messages are you getting?
        • 14989
        Re: Scan to email
        Joe
        • PinkPanther
          • Dec 2016
          • 13
          Re: Scan to email
          The problem is not GMail or others. It is definitely a problem of KM handling mails.
          My Mail-provider doesn't work as well. (Webgo, germany)
          My copier: c224
          The technicians of webgo are very friendly, and also interested in problems.
          So, together we checked all points of communication.
          The bizhub connects perfect to the smtp server, so DNS or IP is not the problem.
          The problem is that the user-ID is not transferred. Without user-ID my provider
          for example cannot work. We tried “SSL” and “TLS”
          Now my user ID is only small letters and numbers. So it is not identical with the
          Mail-address. Maybe that is the problem for the bizhub.
          So I think without firmware-update -as others have stated above- it will be impossible to solve the problem.
          • peter42
            • Jan 2012
            • 110
            Re: Scan to email
            Interesting, any Mailadress is automatically converted into non capial letters in transfer.
            If the username is identical to Mailadress, whats their problem?
            I never had trouble with Email on 250 up to C759, mixed providers like
            vodafon, tkom, Gmail or "In House Mail servers".
            As i mentioned in another thread, check password,
            write it in Notpad, so you can see whats written instead of stars.
            Then copy and paste it into Pagescopes interface.
            Reason:
            If password dont match, you get only the "cant connect to server" error.
            You cant see, if a underline or a minus was mistyped.
            • PinkPanther
              • Dec 2016
              • 13
              Re: Scan to email
              hello Peter,
              you don't understand.
              the 4 series is having a problem.
              My older c203 was mailing without any problem at all.
              It is not because of typo or so.
                • 30523
                Re: Scan to email
                Don't forget to add the email address in the machine setting also or it won't work
                • Woxner
                  • Jul 2011
                  • 854
                  Re: Scan to email
                  do the firmware update andd all mail should work. for some reason the 4 series was not ready for TSL2 only version 1. the older were not affected and the newer were corrected. after firmware it works just fine. also did not affect E series
                    • 14989
                    Re: Scan to email
                    Originally posted by PinkPanther
                    hello Peter,
                    Without the firmware and soft switch change the 4 non e series is incapable of scanning to email with SSL.
                    • peter42
                      • Jan 2012
                      • 110
                      Re: Scan to email
                      Thanks for the input.
