Code to enter service mode? Accurio Press C2060L
  • liondor1969
    • Jun 2016
    • 72
    Please help my with code service mode to AccurioPress C2060..haw to enter in service mode..is possible to fined as service boock for this printer ??
  • Synthohol
    Certified Konica Expert
    • 5804
    Re: Code to enter service mode? Accurio Press C2060L
    hey, thats one beast of a machine there, if you are not trained on it seriously walk away.
    i dont say that to be mean, i say it because they are very sensitive and if you have never worked on one you can accidently cause way more problems than you came there for.
    • liondor1969
      • Jun 2016
      • 72
      Thanks..i buy this is new printer with full service from konica fot 3 yar..i need this cod only for ceck kontor parts.. :-) i not need this for made service..
      QUOTE=Synthohol;594573]hey, thats one beast of a machine there, if you are not trained on it seriously walk away.
      i dont say that to be mean, i say it because they are very sensitive and if you have never worked on one you can accidently cause way more problems than you came there for.[/QUOTE]
      • Synthohol
        • 5804
        print a meter sheet, that has all the info
        • liondor1969
          • Jun 2016
          • 72
          Hy..haw to made a color test drum on service mode..i dont know the code to made this too see wat cilinder drum is with problem..i have a line color
          thanks
          • Synthohol
            • 5804
            Procedure
            1."Service Mode menu screen"
            Press [11 Test Mode]
            2."Test Mode menu screen"
            Press [01 Running Test Mode].
            3."Running Test Mode screen"
            Select the mode to conduct, and press [Print Mode].
            4.Press the Start button to start the running test.
            5.Press the stop button to stop the running test.
            personally id run patterns 62 and 77 to evaluate.
            • liondor1969
              • Jun 2016
              • 72
              Thanks !
              Originally posted by Synthohol
              Procedure
              • wjurls
                • Feb 2017
                • 494
                Just run the density balance chart in the adjustment menu. No need to go into service mode. It will let you see the individual colors.
