Blank copies
  • Reeves
    • Apr 2012
    • 297
    [Misc] Blank copies
    Guys I have a minota C224e colour copier copies r comin out blank drums developer units transfer belt transfer roller looks they r all okey n da fun thing is all da drums r 0% but its not showing any replace drums machine is gettin ready okey
    • 15011
    Re: Blank copies
    Is there an image on the transfer belt if you stop it mid copy?
    Is there something covering the printheads?
    • Albonline
      • Sep 2008
      • 1154
      Re: Blank copies
      if im getting you right, no black while colors work. if even doing this while in test modes. you need an hv unit.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4785
        Re: Blank copies
        The replace drum messages are probably turned off. Did you take out the dev units and look at mag roller to see if toner is on them? This model has issues with dumping developer if consumables are over life.
        Or possible like the other poster said you might have a bad high voltage pwr supply. You can find this out by pulling the trans belt mid cycle and see if image is on it.
        • Reeves
          • Apr 2012
          • 297
          Re: Blank copies
          Originally posted by copyman
          The replace drum messages are probably turned off. Did you take out the dev units and look at mag roller to see if toner is on them? This model has issues with dumping developer if consumables are over life. Or possible like the other poster said you might have a bad high voltage pwr supply. You can find this out by pulling the trans belt mid cycle and see if image is on it.
          No image on transfer belt
          • Reeves
            • Apr 2012
            • 297
            Re: Blank copies
            Is there an image on the transfer belt if you stop it mid copy?Is there something covering the printheads?
            No image on the transfer belt
            • Reeves
              • Apr 2012
              • 297
              Re: Blank copies
              I have checked dev unit they r all okey
              • lazymangr
                • Feb 2017
                • 115
                Re: Blank copies
                if you get color but no black then propably you got faulty K dev clutch. i myself replaced one today. its a pain in the ass to replace it. too much disasembly
                • G6token
                  • Feb 2018
                  • 19
                  Re: Blank copies
                  Did you do any tech work on the copier, replacing removing transfer belt? Drum assembly replacement? Had that problem occur twice with me first when replacing a worn belt and belt cleaner to a housing C554. The new rubber on the cleaning blade was so tight against the new belt it caused the belt to not turn when I installed it. I took it out and backed the screws off just a lil rotated the belt manually a few times against the blade then tightened rotated it few more times and installed it. Problem solved. Had the issue occur with me again but only on the Yellow. I was replacing the drum and cleaning blade on a drum unit for a c 454 and the cleaning blade rubber caused it not to rotate not giving me any yellow on the image. Friction between rubber and the metalish lol. I just roatated it manually a few times until I felt the resistance loosen. Installed it. Problem solved.
                  • mihailelea
                    • Jan 2018
                    • 44
                    Re: Blank copies
                    I had this problem with an HP.
                    I cleaned it with compressed air, and put some adhesive tape on the laser unit gap (the gap witch the laser comes out from and goes to the drum). I'm sorry I don't have the words to explain this any better, but I'm sure you understand.
                    I've put the adhesive tape there so no dust from the printer can enter the laser unit when I blow compressed air.
                    Anyway, I forgot the adhesive tape there and obviously the pages came out blank.
                    What I'm trying to suggest is to see if the laser from the laser unit is coming out. Maybe the gap is obstructed somehow or the laser unit is not in it's place.
                    It's just a suggestion...
                    • REGSIS
                      • May 2016
                      • 437
                      Re: Blank copies
                      Or solenoid next to the clutch is the most probable cause of this failure.
                      Solenoid is stuck, hence black dev unit is not rotating, causing no black picture issue.
                        • 15011
                        Re: Blank copies
                        He never said anything about having colour but no black. He said blank
                          • 15011
                          Re: Blank copies
                          No, he said "blank" pages
