bizhub 283 replenish paper
  • xmicemanx
    • Dec 2017
    • 7
    bizhub 283 can detect the size of paper but when printing it a message pops out replenish paper..how to fix this problem
    • 14813
    Re: bizhub 283 replenish paper
    What have you done so far? It makes it easier to help if we aren't suggesting things you have already done.
    • xmicemanx
      • Dec 2017
      • 7
      nothing..the machine is ok before they transffered it to other location..
        • 14813
        Then I would suggest getting a qualified tech to look at it. He/she will know how to troubleshoot the issue for you.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4723
          sounds like the paper end sensor got dislodged or broken when machine was moved. Paper tray determines size by moving the guides, this is why it can detect size. The paper end sensor hangs down down and contacts paper. Remove both paper trays and you should see a lever hanging down from the top of cavity, compare to the other one that is working ok. you should see it broken or loose. You will probably have to remove paper feed unit to repair.
          • Synthohol
            Certified Konica Expert
            • 5849
            what is the exact message?
            does it ask to put paper on the bypass tray? if so maybe either the machine has a special paper in the tray settings or the driver does.
            make sure the trays are set to plain paper and the same with the print job.
            • notKarl1
              • Oct 2017
              • 2
              check paper drawer for cracks as well.
              • Jhonjon
                • Sep 2013
                • 208
                Check if this part if it is broken.
