Bizhub C554 Removing Equitrac
  • greg0105
    • Jul 2014
    • 4
    Hi all
    We picked up a KM Bizhub C554 which has Equitrac installed.
    Is there a procedure to remove the software. Have searched hi and low.
    Any help appreciated.
  • Synthohol
    Certified Konica Expert
    • 5823
    Re: Bizhub C554 Removing Equitrac
    turn off vendor mode in stop 9
    • emujo2
      • Mar 2017
      • 1579
      Equitrac is just a 3rd party software, you can disable the authentication requirements by going on to admin mode and turning user authentication to off. This will not remove the app itself. If you are a KM dealer or direct you should have access to the Open API tool which can be used to safely remove any leftover remnants of the App. A HDD format should do the trick as well. The vendor modes posted suggestion is probably referring to disabling the card reader if installed and is done in the billing settings, not vendor mode. Emujo
        • 23007
        In the few cases, I've formatted the drive and reloaded firmware. Good as new. =^..^=
        • mincopier
          • Dec 2015
          • 289
          Enter service mode then Stop 9 as mentioned above. I forget which options are there but I believe it is easy enough to figure out once there.
