C227 / C308 series Mac driver issue
  • copytechman
    • Nov 2008
    • 931
  • jasoon88
    • Feb 2018
    • 3
    Re: C227 / C308 series Mac driver issue
    Yes I noticed that too, use older driver and it seem to have the old screen however safari still shows printer feature. Account track does not pop up with new driver on mac
    Sent from my LG-H831 using Tapatalk
    • Synthohol
      Certified Konica Expert
      • 5808
      i just read if you install an older version first then the latest the popup box can be enabled.
      if i remember where the KB article is ill post it.
      • copytechman
        • Nov 2008
        • 931
        • Synthohol
          • 5808
          wait, are you looking for the same options as windows like preferences and stuff?
          you need to enable the web interface via terminal
          go to localhost:631/printers and select the printer and in the administrator drop-down choose default options.
          is that what you meant?
          • copytechman
            • Nov 2008
            • 931
            No, when you install the latest km c308 / c227 driver for Mac on the latest Mac os I have found that the Mac driver "properties" don't show properly, just printer features which isn't correct. That's if you install as an ip device. If installed as a bonjour device it looks proper. Don't know why this has started to occur it never did before and it's very annoying.
            Regards.
            A.
            • jasoon88
              • Feb 2018
              • 3
              This one worked for me. But not when your printing from safari. Everything else ok. Remember to close applications and relaunch then test printing.
              Version 9.1.7
              8/8/2017 78.56 MB
