bizhub 501 Light Prints/Copies
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    [CQ] bizhub 501 Light Prints/Copies
    We have a Konica Minolta bizhub 501 that continually keeps reverting to light prints and copies. The technician that took care of those machines has left and we believe he was manually adding toner via the following:
    1. "Service Mode screen"Press [State Confirmation].
    2. "State Confirmation screen"
    Press [Sensor check].
    3. "Sensor Check screen"
    Press [Check Code] and, when entering the sensor check code in 3 digit through the copy count setting
    button, a state (ON/OFF or value) is displayed in the Result area.
    4. For the multi mode, press [Multi Code] and enter a three-digit multi code through the copy count setting
    key.
    5. When conducting the sensor check of other signal sources, repeat steps 3 to 4.
    Performing the following inputs:
    55 1 M4 Toner supply motor
    2 SD5 Toner solenoid
    3 M4,
    SD5
    Toner supply motor, toner solenoid
    turn ON at the same time
    But it keeps getting light again, Is there anything besides:
    TCR Adjustment
    and
    Toner Density Adjustment
    and
    Laser Diameter Adjustment
    That we can do? Please help?
    It does not matter how slowly you go as long as you do not stop. –Confucius
  • Woxner
    • Jul 2011
    • 853
    Re: bizhub 501 Light Prints/Copies
    how old is the dev. its good for 250k. will go longer but may have issues. you should not tone up then run tcr. its best to start new. probably not toner add because you have no codes. also be sure to reset dev count before doing tcr for new dev. drum is 250k as well
