C224/C224e Firmware & Movie Data
  • CopierShaman
    • Mar 2018
    • 6
    Can I get the firmware & movie data for the above 2 models from someone? Thanks.
  • Synthohol
    Certified Konica Expert
    • 5892
    Re: C224/C224e Firmware & Movie Data
    just an offer, donate some money to this site, become a contributor and ill send you the link to everything
    • jonbonse
      • Jun 2009
      • 737
      Hi, I have the latest firmware for the C224e but not the non E model C224..... Could you help with a link?
      • Synthohol
        • 5892
        PM sent.
        thanks for contributing!
          PM sent.
          Thanks brother...
          you are a top notch tech IMHO
          • jonbonse
            • Jun 2009
            • 737
            PM sent.
            Thank you!
            • koopia
              • 9
              Hello i have a problem with my c224e. I have movie data but if i install it, it goes 215000kb and stop Not good(Ng).
              Firm what i have F000-G20-MJ-960 and movie file is a5c1an.tar
              can someone help me please!
              • tulintron
                • Jul 2014
                • 668
                Can you report what your problem is?Why update your firmware?
                Your version of Movie Data is correct and can work without it.
                • tsbservice
                  Field tech
                  • 8053
                  Did you removed old Movie data before attempting new one? Also your HDD may start to fail, did you happen to format it before?
                  • copier tech
                    • 8200
                    That movie file is correct for the C224e series (for function version 3 & later)
                    Try updating the main firmware then try again.
                    Firmware Readme C224e C284e C364e GDN-M1.pdf
                    • koopia
                      • 9
                      i haven't had movie data since the hdd is formated. i want to install it because then nothing will flash and the customer would be happy too, but some how its impossible.
                      one question more i had reset the password before when i install the new firmware either also then the service password must be again 9272 x4 the machine did not ask for a password.
                      i think firmware maybe not install correctly
                      • koopia
                        • 9
                        problem is i want install movie data. hdd is formatted and all data lost. its very annoying if its flashes and text say all the time no animation.
                        [ATTACH]46602[/ATTACH]
                        i put again firmware, but still same problem stuck and saying not good.
                        • koopia
                          • 9
                          i noticed that when the download is complete the ADF, MFP, SCANNER says (check sum) but the PRINTER just Download Completed? is that a problem? what does this check sum mean?
                          • copier tech
                            • 8200
                            Check sum is normal so is completed.
                            What version firmware did you update to? & what function version is the machine set to?
                            • tulintron
                              • Jul 2014
                              • 668
                              Movie Data in PM
