bizhub 1250 cannot pull out process unit
  • acsolutions
    • Jun 2010
    • 519
    [Misc] bizhub 1250 cannot pull out process unit
    Hello, Customer got some labels stuck in the processor. I removed the front cover, drum shaft knob, removed two screws, released toner hopper and two latches released. The unit pulls out about 1/8 inch but thats it. Is there anything else holding it back? I left the customer site and forgot to open the right side door to see if that was the holdup. does that door need to be opened? Any suggestions would be great. thanks
  • Flash
    • 378
    Re: bizhub 1250 cannot pull out process unit
    Someone may have left the latch for the cleaning unit in the up position. You may be able to push the front one down with a long flat blade if you can get to it. If it is a 1250P you can go through the top to access the front and rear latches.
    • acsolutions
      • Jun 2010
      • 519
      Thats awesome Flash! Here is a pic if you could point it out. thanks so muchIMAG0924.jpg
        • 23009
        My guess is that the drum shaft is seized to the drum bearings. If it were me, I would apply a couple drops of penetrating oil (like Marvel Mystery Oil) to the spot where the drum shaft meets the front bearing. Then I would apply some pulling pressure with my left hand on the image unit, and with my right hand GENTLY tap on the end of the drum shaft with a small hammer. The vibration from the tapping helps the oil penetrate. If you do it right you won't fall on your ass when it comes loose. =^..^=
        • acsolutions
          • Jun 2010
          • 519
          Thanks Blackest, the machine only has 143k on the machine, could there be caught on a burr or something
          • Synthohol
            Certified Konica Expert
            • 5846
            if the ADU is pulled out the process unit is locked in place.
            close the adu and the process unit will be released.
            • acsolutions
              • Jun 2010
              • 519
              I tried with the transport section pushed in and pulled out. The lever was definitely released too.
              • allan
                RTFM!!
                • 5462
                Yank it...
                Could be bad advice, make sure the connectors are disconnected.
                Found that if one on the flanges from the drum turns slightly skew it binds good.
                In your case it moves a bit.
                Whatever
                • allan
                  RTFM!!
                  • 5462
                  How did that drum knob come off?
                  Some of those bits are on the picture?
                  Whatever
                  • Synthohol
                    • 5846
                    LOL. I didn't even notice the drum screw wasn't removed. Yeah put the handle back on and unscrew the shafts correctly
                      • 23009
                      How did I miss that?!
                      Yes, just put the handle back on the shaft and unscrew the handle ASSEMBLY from the drum shaft.
                      I never thought of doing it that way. =^..^=
                      • acsolutions
                        • Jun 2010
                        • 519
                        [ATTACH=CONFIG]39117[/ATTACH]
                        There were two screws holding the knob on and there was a sleeve that the knob fit over. That was ir
                        • acsolutions
                          • Jun 2010
                          • 519
                          So, the drum shaft unscrews?
                          • acsolutions
                            • Jun 2010
                            • 519
                            Is that a 1250 manual. Wow that's awesome guy
                              • 23009
                              Just the last 50mm to the front. =^..^=
