C224/224e blocking junk faxes ???
  • copyman
    Owner / Technician
    • Sep 2005
    • 4664
    Customer asked if there was a way to block junk faxes? I looked in user and service manuals and only thing I found was to have all faxes go into a box then print out just the faxes you want. I remember back when I was working on a lot of stand alone fax machines you could block individual #'s. But back then fax machines were used to advertise a lot (no internet) . Customers would get a bunch of junk faxes everyday like lunch menus, travel ads, etc. until finally OEM's added the "anti-junk" feature, which is basically a number block.
    Thanks in advance
  • allan
    RTFM!!
    • 5462
    Re: C224/224e blocking junk faxes ???
    Send to email and let outlook do the job?
    Whatever
      • 23003
      Most fax machines now can authenticate against the addressbook. In other words, if it's in the addressbook it will accept a fax Rx, if it's not in the addressbook it won't Rx. That's about as close as you'll get. =^..^=
        • 30086
        Junk Faxes are great. Remember you only make money on output. Forward to email makes your owner ZERO dollars. WOW say they get 5 junk faxes at day, a whole 5 cents. Don't waste your time
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          What about all the fun we had in the c360 days with spam faxes of subway lunchtime preordering sheets with excessive coverage getting wrapped around fusing rollers.
