Joining a domain for single sign on
  • rrrohan
    • Sep 2011
    • 1976
    Having some issues joining to a domain. It's 1st time i have tried.
    IT says it want hostname of copier, domain and admin credentials.
    Provided all that but no good.
    I see there are different authentication methods also
    Active directory
    LDAP
    Ntlm v1 v2 and v3
    Problem is customers IT obviously doesn't want to give me the domain password and he got fed up with typing it in as i did some trial and error.
    Any tips?
    I'm sure im missing something simple
  • Synthohol
    Certified Konica Expert
    • 5807
    Re: Joining a domain for single sign on
    what about joining a domain? they should be printing by IP not windows lame SMB printing.
    if the SMB scanning is an issue you can try their domain name under workgroup otherwise the scan credentials may need to include the domain name first.
    ie: copytechnet\synthohol
    ill send you the SMB guide links via PM.
      • 22999
      I think he's trying to authenticate the machine against LDAP, to control usage. =^..^=
      • Synthohol
        • 5807
        so in admin there is authenticate to external server.
        also he should create a user called service and give you a password. that might help!!
        • rrrohan
          • Sep 2011
          • 1976
          single user sign on is so that we can link to AD so user authetication is managed by AD and not the local copier.
          its also so that when we roll out the driver we dont have to manually assign credentials.
          keep in mind this is the plan, i have never attempted it.
          Also i get the impression this will also allow self association of swipe cards.
          all of this is worth the effort of researching as they are rolling out over 10 copiers and not having to do this on each will drain the life from me
          i told him he can always change the password once i get it working but he made it seem like a huge security issue like he was in the military.
          • B0265
            • Jan 2007
            • 718
            Is the MFP setup with external server authentication?
            From the user's guide:
            Join the machine to the Active Directory domain and establish the single sign-on environment.
            You can set this option by selecting [External Server Authentication] or [Main + External Server] in
            [Administrator Settings] - [User Authentication/Account Track] - [General Settings] - [User Authentication] -
            [Authentication Method].
            Self association of swipe cards is another story, search for "LDAP-IC Card Authentication Setting" in the user's guide.
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              Funny that, considering this is the exact setup that is used in such places here
              • rrrohan
                • Sep 2011
                • 1976
                wow you have the military domain password? I cant even get a real estate domain password half the time lol
                • EarthKmTech
                  Step aside, noob
                  • May 2009
                  • 2139
                  No, their ICT sets that all up.
                  Real estate agents are usually pretty relaxed with network security I've found, a little too relaxed. A mixture of branch owned PC's and personal laptops running god knows what and half the people not even there when you want to do an install. Some can be extremely finicky about the most trivial issues and are nickel and dime customers while others are relaxed and pump out massive volumes of colour too. Luck of the draw.
                  • rrrohan
                    • Sep 2011
                    • 1976
                    so you got experiance setting it up or you handball it to the IT.
                    none of our techs really interested in figuring out the more advanced configs if it takes more than 10 mins to get working so if I dont work it out I fully expect it will never be used.
                    are you able to offer any pointers?
                    It did give us various errors but all very vague.
                    one was that it couldnt connect and the other was "unspecified error"
                    i will get exact wording of the error tomorrow
