Bizhub 227
  • scanmc
    • Mar 2015
    • 183
    Bizhub 227
    I've got a Bizhub 227 that on cassette #2 reads A3 instead of 11x17. pulled out the cassette and every thing seems to be in place and all switches in the machine are working properly. I loaded 81/2 x11 in the same cassette and it detects A4 Any thoughts would be appreciated but I'm leading to something going on with the cassette?
    Re: Bizhub 227
    .... try manually setting tray properties via the machine. or in the machine set the measurement from MM - Inch
    • scanmc
      • Mar 2015
      • 183
      Re: Bizhub 227
      Machine is set for auto detect .Tray one is only letter - legal size and working properly. When I was out there I didn't even try to insert tray #1 into tray #2 slot as I assumed it was different but maybe I should have rather than assume. If I had a cassette for testing but don't as this is a one of a kind for me
      • copyrooks
        • Oct 2013
        • 210
        Re: Bizhub 227
        I attached a bulletin from KMBS. Also they redid the trays for the refresh model that also works with the non refresh models and honestly that fix for the bulletin doesn't seem to stick. I usually get callbacks every couple months with the customers stating same issue. If able to just order the new tray it works way better than the old ones.
        • scanmc
          • Mar 2015
          • 183
          Re: Bizhub 227
          Copyrooks. Thanks for the update bulletin ---I was thinking it was something along those line.
          • Woxner
            • Jul 2011
            • 850
            Re: Bizhub 227
            i replace the old trays with the new ones and has worked fine since. the bulletin is a waste of time
