Bizhub 227
  • Woxner
    replied
    Re: Bizhub 227
    i replace the old trays with the new ones and has worked fine since. the bulletin is a waste of time
  • scanmc
    replied
    Re: Bizhub 227
    Copyrooks. Thanks for the update bulletin ---I was thinking it was something along those line.
  • copyrooks
    replied
    Re: Bizhub 227
    I attached a bulletin from KMBS. Also they redid the trays for the refresh model that also works with the non refresh models and honestly that fix for the bulletin doesn't seem to stick. I usually get callbacks every couple months with the customers stating same issue. If able to just order the new tray it works way better than the old ones.
  • scanmc
    replied
    Re: Bizhub 227
    Machine is set for auto detect .Tray one is only letter - legal size and working properly. When I was out there I didn't even try to insert tray #1 into tray #2 slot as I assumed it was different but maybe I should have rather than assume. If I had a cassette for testing but don't as this is a one of a kind for me
    replied
    Re: Bizhub 227
    Originally posted by scanmc
    I've got a Bizhub 227 that on cassette #2 reads A3 instead of 11x17. pulled out the cassette and every thing seems to be in place and all switches in the machine are working properly. I loaded 81/2 x11 in the same cassette and it detects A4 Any thoughts would be appreciated but I'm leading to something going on with the cassette?
    .... try manually setting tray properties via the machine. or in the machine set the measurement from MM - Inch
  • scanmc
    started a topic Bizhub 227
    Bizhub 227
