Bizhub C253 Many Lines without print image
  • Powerfabi
    • Jul 2025
    Has anybody ever seen such a printed image?
    Bizhub C253! All colors have the same problem. 28942812_10215454920115627_2143661016_o.jpg28942812_10215454920115627_2143661016_o.jpg
    • 23007
    Re: Bizhub C253 Many Lines without print image
    I saw something like this on a Toshiba Weisshorn 2H, after a power outage/surge.
    I interpreted it to be laser self-focus problem. What I did is run the color calibration ... perhaps 20 times. Each time I did it it came back a little better. If I had done it ... oh ... 10 more times, it would have been perfect, but by then I was getting pretty irritated at how slowly it was coming back.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4685
      Doing it when copying & printing? All internal test pages do the same thing? Any codes?
      I agree with BC it has something to do with the printhead. But since this has 4 separate laser units and all couldn't be bad I would look at a board as the problem.
        • 23007
        These are the samples I made: Does it look familiar:
        • Powerfabi
          Thank you for the answers.
          There are no codes.
          Color calibration makes no difference.
          The same problem by copying and printing.
          I swapped the mfp board but unfortunately without success.
          Now, I will change the controller, because the ribbon cable of the laser units goes directly to the controller.
