C6500 install. Fiery and driver cannot locate Printers IP address.
  • swaggen
    • Sep 2017
    • 100
    #46
    Re: C6500 install. Fiery and driver cannot locate Printers IP address.
    Change port. Same issue.
    • Synthohol
      Certified Konica Expert
      • 5822
      #47
      is it a PDF? put the job on a flash drive and plug it into the copier USB next to the LCD panel.
      an icon should popup asking to print a doc from external memory select it and try to print. see if it still fails.
      also only change the fiery to LPR not the x54s
      • swaggen
        • Sep 2017
        • 100
        #48
        We have certain fonts we print... printing via memory still ... turns it to text. It prints right away and does not fail.
        • Synthohol
          • 5822
          #49
          is spool to hdd enabled in printer settings?
          • swaggen
            • Sep 2017
            • 100
            #50
            I do not see that under any printer settings.
            The error reads as a time out error. I maxed out the time out error on all 3 printers. I updated firmware. Got rid of universal drivers. No change.
