C6500 install. Fiery and driver cannot locate Printers IP address.
Re: C6500 install. Fiery and driver cannot locate Printers IP address.
is it a PDF? put the job on a flash drive and plug it into the copier USB next to the LCD panel.
an icon should popup asking to print a doc from external memory select it and try to print. see if it still fails.
also only change the fiery to LPR not the x54s
We have certain fonts we print... printing via memory still ... turns it to text. It prints right away and does not fail.
