bizhub 185 paper jan in exit section.
  • axel
    • Sep 2011
    • 36
    [Jamming] bizhub 185 paper jan in exit section.
    paper jam in exit sensor.
    the actuator is remaining on after the paper pass.
    there is no part number for the actuator.there is part number only for the FUSING & PAPER EXIT SECTION.
    any idea?
  • Toxic
    • 698
    Re: bizhub 185 paper jan in exit section.
    Remove exit section without removing fusing unit,watch to not lose fingers when removing.
    Remove actuator and spring,clean actuator and make one more turn with spring so make it stronger so it have more power to return actuator to home position.
    • axel
      • Sep 2011
      • 36
      Originally posted by toxic
      remove exit section without removing fusing unit,watch to not lose fingers when removing.
      i try this and i solve the problem.
      Thank you very much.
      • Toxic
        • 698
        Recently have same problem and figure out what to try and it works.
        Glad to help you.
