Konica C6000: Gamma correction abnormality
  • cxtqd
    • Jan 2011
    • 46
    When Konica C6000 printing is abnormal in color. It is almost impossible to see 4 CMYK colors. Experts advise me on how to deal with this. Thank you.
  • cxtqd
    • Jan 2011
    • 46
    Re: Konica C6000: Gamma correction abnormality
    I replaced all new materials like drums, charging, develop, belt... PRCB, PRIPB, Image correction unit, Laser unit...
    • Desert Rat
      • May 2008
      • 1089
      Do you have the service manual?
      In the book it tell you what programs (adjustments) to run after replacing parts.
      Make sure the gamma sensor and registration sensors are clean.
      There is a program called the gamma off set adjustment. I usually run this adjustment
      after replacing the drums, developers and chargers. Keeping the machine clean inside
      will help a lot. Make sure the laser windows are clean. If they are not the output will
      be light in appearance.
      I will post the order of the adjustments later.
      DR
      • cxtqd
        • Jan 2011
        • 46
        i have the service manual.
        • cxtqd
          • Jan 2011
          • 46
          The printer is automatically adjust after error C-4601
          • Synthohol
            Certified Konica Expert
            • 5814
            mandatory adjustments after replacing the laser(s)
            After replacing the writing unit /K, conduct the following item.
            - Cleaning the dust proof glass (Refer to F.5.2.1 - Cleaning the
            dust proof glass
            - Writing initial position memory (Skew initial position memory)
            (Refer to I.5.3.9 Skew Initial Position Memory (Printer Adjustment -
            Writing Initial Pos. Memory)
            - I/O Check Mode (LD1 to LD8 alarm data clear, LD alarm
            measurement) (Refer to I.5.7.1 I/O Check Mode)
            - CD-Mag. Skew Adj. (Refer to I.5.3.13 CD-Mag. Skew Adj.
            (Printer Adjustment)
            - Restart Timing Adjustment (Refer to I.5.3.1 Restart Timing
            Adjustment (Printer Adjustment)
            - Color Registration Auto.Adj. (Refer to I.5.3.10 Color Registration
            Auto.Adj. (Printer Adjustment)
            - Color Registration Manual (Refer to I.5.3.11 Color Registration
            Manual (Printer Adjustment)
            - Gamma Automatic Adjustment (Refer to I.5.4.7 Gamma
            Automatic Adj. (Drum Peculiarity Adjustment)
            - Beam Pitch Adjustment (Refer to I.5.3.14 Beam Pitch Adjustment
            - Moire Adjustment (Refer to I.5.3.15 Moire Adjustment (Printer
            Adjustment)
            8. After replacing the writing units /Y, /M, /C, conduct the following
            item.
            dust proof glass
            Adjustment)
            mandatory adjustments after replacing developer...
            - Counter reset of the parts counters No.41, 42 for the developer /
            Y, No.43, 44 for /M, No.45, 46 for /C,and No.47, 48 for /K.
            - Toner Density Sensor Init. (Refer to I.5.4.9 Toner Density Sensor
            Init. (Drum Peculiarity Adjustment)
            Printer Gamma Offset Auto. (Refer to I.5.3.23 Printer Gamma
            Offset Auto. (Quality Adjustment - Printer Gamma Adjustment)
            mandatory adjustments after replacing drum(s)
            After replacing the drum cartridge, conduct the following items.
            - Cleaning the dust-proof glass (Refer to F.5.2.1 - Cleaning the
            dust proof glass
            - Counter reset of the parts counter No.21, No.22 for drum
            cartridge /Y, No.23, No.24 for drum unit /M, No.25, No.26 for drum
            unit /C, No.27, No.28 for drum unit /K
            depending on the firmware there is a selection for running all drum peculiarity adjustments that goes from one screen to the next.
            best to use that.
            bad part is if you didnt run the toner density adjustment immediately after completely vacuuming out the units and refilling them all your adjustments will be for nothing.
            these machines are really finicky if you don't follow the manual to the letter. any skipped or step out of order and its a waste of time and developer.
            good luck!!
            • Desert Rat
              • May 2008
              • 1089
              Thank you for posting that Synthohol, my computer went down and I was unable to access my manuals.
              Synthohol is giving you the best advice. I'm curious, why did you replace the OCB and the write units?
              Generally I would do the PM and the adjustments before I would start replacing boards and write units.
              Even then I would post a question before replacing those parts.
              DR
              • qmuadhi
                • Mar 2019
                • 3
                Does bizhubpress c6000 have pcl drivers
                Sent from my SM-A600F using Tapatalk
                • Synthohol
                  • 5814
                  not that i saw, its PS or XPS.
                  • qmuadhi
                    • Mar 2019
                    • 3
                    How do I get xps and does it have abetter print out than ps thanks
                    • tulintron
                      • Jul 2014
                      • 668
                      Good morning everyone. In some cases I solved it by running Recall Standard Data for Factory Default in Process Adjustment and Quality Adjustment. I observed that it happened in cases where the batteries were already exhausted and because of persisting, cases like these happened.
                      The values are saved in the NVRam and in some cases, the simple procedure of changing the batteries is not enough.
                      Try the Recall and then perform the battery replacement procedures.
                      Good luck.
                      • Synthohol
                        • 5814
                        xps is crap, whats wrong with postscript? it has a larger font table and more accurate color.
                        what controller?
                        ic601
                        ic306
                        ic307
                        ic413?
                        • Toxic
                          • 697
                          @tulintron
                          Can you share some more info about this NVRAM battery and replacement procedure,never done that.
                          Have C5501 with strange problem,every morning for a long time shows C2804 and sometimes C4520,gamma adjustment or recall to factory resolve problem till next morning.
                          Rerely in the middle of print full black turns to grey color.
                          It could be something with NVRAM and i did not know about battery and i would like to try that.
                          • tulintron
                            • Jul 2014
                            • 668
                            Originally posted by Toxic
                            @tulintron
                            The batteries in which I referred, are the replacement parts and not the bundles of the NVRam.
                            If you release the NVRam batteries, you can throw the machine in the trash
                            • Toxic
                              • 697
                              Never seen any battery in this machine and also can not find anything in PM and SM...
                              I assume that the battery is on some board?
