Konica C6000: Gamma correction abnormality
  • qmuadhi
    • Mar 2019
    • 3
    #16
    Re: Konica C6000: Gamma correction abnormality
    Originally posted by Synthohol
    not that i saw, its PS or XPS.
    How do u get xps drivers
    Sent from my SM-A600F using Tapatalk
    • Synthohol
      Certified Konica Expert
      • 5808
      #17
      LMGTFY ,--click here
      • Rohullah
        • Sep 2019
        • 37
        #18
        mandatory adjustments after replacing the laser(s)
        After replacing the writing unit /K, conduct the following item.
        - Cleaning the dust proof glass (Refer to F.5.2.1 - Cleaning the
        dust proof glass
        - Writing initial position memory (Skew initial position memory)
        (Refer to I.5.3.9 Skew Initial Position Memory (Printer Adjustment -
        Writing Initial Pos. Memory)
        - I/O Check Mode (LD1 to LD8 alarm data clear, LD alarm
        measurement) (Refer to I.5.7.1 I/O Check Mode)
        - CD-Mag. Skew Adj. (Refer to I.5.3.13 CD-Mag. Skew Adj.
        (Printer Adjustment)
        - Restart Timing Adjustment (Refer to I.5.3.1 Restart Timing
        Adjustment (Printer Adjustment)
        - Color Registration Auto.Adj. (Refer to I.5.3.10 Color Registration
        Auto.Adj. (Printer Adjustment)
        - Color Registration Manual (Refer to I.5.3.11 Color Registration
        Manual (Printer Adjustment)
        - Gamma Automatic Adjustment (Refer to I.5.4.7 Gamma
        Automatic Adj. (Drum Peculiarity Adjustment)
        - Beam Pitch Adjustment (Refer to I.5.3.14 Beam Pitch Adjustment
        - Moire Adjustment (Refer to I.5.3.15 Moire Adjustment (Printer
        Adjustment)
        8. After replacing the writing units /Y, /M, /C, conduct the following
        item.
        dust proof glass
        Adjustment)
        mandatory adjustments after replacing developer...
        - Counter reset of the parts counters No.41, 42 for the developer /
        Y, No.43, 44 for /M, No.45, 46 for /C,and No.47, 48 for /K.
        - Toner Density Sensor Init. (Refer to I.5.4.9 Toner Density Sensor
        Init. (Drum Peculiarity Adjustment)
        Printer Gamma Offset Auto. (Refer to I.5.3.23 Printer Gamma
        Offset Auto. (Quality Adjustment - Printer Gamma Adjustment)
        mandatory adjustments after replacing drum(s)
        After replacing the drum cartridge, conduct the following items.
        - Cleaning the dust-proof glass (Refer to F.5.2.1 - Cleaning the
        dust proof glass
        - Counter reset of the parts counter No.21, No.22 for drum
        cartridge /Y, No.23, No.24 for drum unit /M, No.25, No.26 for drum
        unit /C, No.27, No.28 for drum unit /K
        depending on the firmware there is a selection for running all drum peculiarity adjustments that goes from one screen to the next.
        best to use that.
        bad part is if you didnt run the toner density adjustment immediately after completely vacuuming out the units and refilling them all your adjustments will be for nothing.
        these machines are really finicky if you don't follow the manual to the letter. any skipped or step out of order and its a waste of time and developer.
        good luck!!
        Dear Synthohol
        Can you send me this manual? I realy need that.
        my email:info@kabulpen.co
        Thanks in advance
        • Synthohol
          • 5808
          #19
          i only share with people with a contributor badge. its not personal.
          https://www.copytechnet.com/forums/v....php?do=donate
          • Walterj
            KONICA MINOLTA
            • Jun 2017
            • 89
            #20
            Originally posted by cxtqd
            I replaced all new materials like drums, charging, develop, belt... PRCB, PRIPB, Image correction unit, Laser unit...
            Good Day
            Dear
            I hope this contribution helps
            I think you should check the HV boards
            I imagine that you have reset the counters of the replaced inputs and made the adjustments according to the technical service manual
            Regards
