Bizhub 920 duplex print: too light
  • ondemandprint
    • Sep 2016
    • 87
    [CQ] Bizhub 920 duplex print: too light
    Bizhub 920 issue.
    There is a problem with print quality. While duplex printing from computer: 1st side has a normal density, but 2nd side is much more light.
  • Synthohol
    Certified Konica Expert
    • 5816
    Re: Bizhub 920 duplex print: too light
    duplex does second side first first side second. may be damp paper? once it goes through the fuser for the "second side" the paper dries more and the second image (first side) is transferred to paper better.
    • Toxic
      • 697
      I have the same problem today with Bizhub 950.
      I try good 80gsm paper and its the same.
      Interesting is when set paper as 130-160gsm only duplex side print is light on every sheet but when set paper to 80gsm it is much better and 1 of 5 sheets is light.
      Drum,developer,coronas,fuser,... is rebult with new parts (not by me),i just get this machine.
      Could it be something with transfer assist sheet?
      • methogod
        • Dec 2008
        • 920
        super odd...
        What happens when you print a test page from copier - not print...
        does it do the same in duplex mode?
        make sure not file or controller...
        10 year old hard drive be acting crazy AF.
        • Toxic
          • 697
          I did not even try print yet,i see this problem on copy.
          Tryed copy from glass and adf,same thing.
          • methogod
            • Dec 2008
            • 920
            test print from service.. duplex.
            • ondemandprint
              • Sep 2016
              • 87
              Problem is solved.
              57GAR71400 Separating Assembly have been restringed. Strings were too burned and assembly can't maintenance right charge value for the 2nd side as I see. It prevents normal transfer on already charged (after 1st side printed) paper.
