Bizhub C280 Faded Black
  • DSharpe
    • Apr 2018
    • 36
    [CQ] Bizhub C280 Faded Black
    Whats up guys? Ive got a c280 that has fairly low miles on it. It has a new drum, belt unit and hopper unit installed. The machine will be running fine and then all of a sudden the black drops almost all the way out. it was running the other day and just started. I ran initialize+stablize and everything come back to normal but this is only temporary. All the while its running with hardly any black there is no P codes or any other type of codes. After i did the initialize+stablize is when the codes come up. Run grad adjust and everything is good to go temporarily. Attaching sample. Thanks for your help.
    • 23010
    Re: Bizhub C280 Faded Black
    Sounds like the developer drive clutch to me. =^..^=
    • DSharpe
      • Apr 2018
      • 36
      Does this just cause the DV Unit or mag roller to quit turning?
        • 23010
        Yes. =^..^=
        • DSharpe
          • Apr 2018
          • 36
          Yes. =^..^=
          Much Appreciated!! and thank you for the quick response.
          • allan
            RTFM!!
            • 5462
            Don't think its the clutch black is developing. There the text font is missing.
            Fixed this before by restarting before.
            Whatever
            • DSharpe
              • Apr 2018
              • 36
              Hey Guys, the black developer clutch did fix this issue! Thanks again
                yes
