Konica 654e
  • antone
    • Oct 2014
    • 344
    Konica 654e
    Intermittent light copies glass,doc feeder,printing! First couple fine,than light copies....than good copies. FIRMWARE fine passed all test ect.any thing to add
    Sent from my SM-N950U using Tapatalk
  • eccelobo
    • 113
    Re: Konica 654e
    Is it doing so for all colors? If so, I'd check the 2nd transfer roller.
    Enviado desde mi SM-G920V mediante Tapatalk
    • antone
      • Oct 2014
      • 344
      Re: Konica 654e
      Its B/W....and I did check 2nd transfer roller ect
      • Bernard
        • Aug 2011
        • 14
        Re: Konica 654e
        I would check the transfer unit ... retraction mechanism. Maybe swap it out.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4632
          Re: Konica 654e
          If it's only B&W I would look at the black imaging unit causing it, drum or the developer.
            • 22999
            Re: Konica 654e
            Yup, your drum will start to get primary charge voids around 500K. =^..^=
