C454e
    • 14970
    C454e
    I have a customer with a C454e and they want to make one of the paper trays inaccessible. I can do this at the machine by creating a custom screen profile. The question I have is, is it possible to make the paper tray inaccessible from the print driver? They want to put cheques into this tray and not have people print or copy onto them except the person who is supposed to print on them.
    Any help is appreciated.
    • 30476
    Re: C454e
    Yes just pick a paper type. But leaving blank checks in copier all the time?????????
    Seems retarded as ANYONE can take them.
    Would get that person there own desktop printer
    Don't think you could do from the driver as if they print from MS and pick that tray it will override any print driver setting
    • copyman
      Owner / Technician
      • Sep 2005
      • 4756
      Re: C454e
      Think the easiest way would be to set that tray to custom or special. Then the only way it will pull from that tray is if you go into printer properties and select it.
        • 14970
        Re: C454e
        Unfortunately just picking a paper type does not isolate the tray. I am aware of this option.
        What the customer would like is for the tray to be unavailable for anyone but the person printing cheques.
        Also, they are considering putting a hasp and lock on the tray to keep it secure(ish).
        Thanks for the suggestions.
        • K-3
          service technician
          • Feb 2018
          • 51
          Re: C454e
          i don't think this is possible to isolate only one tray, except by changing paper type so no one else can print to it by accident or on purpose. you could try changing default trays for printing, but if someone picks that tray from driver it will print to that tray.
          • SmellsHot
            Head Tech
            • 512
            Re: C454e
            Go into user settings, paper tray settings. You can un highlight which tray has checks from the "auto" feature. This works for both copying and printing. The only way the tray can be used is if it manually selected by the person. I would also recommend changing the paper type if they have more than two trays and want to keep tray switching functional.
            Everyone has the right to be stupid. Some people just abuse this privelage more than others
            • Synthohol
              Certified Konica Expert
              • 5888
              Re: C454e
              Why don't they use the bypass for checks like a normal user?
              If they print that many checks get a 100.00 printer at staples and be done with it.
                • 14970
                Re: C454e
                They print to a desktop printer now, but they want to consolidate all their printing to the C454e. The more they print to it the better for us, and them.
                I didn't tell them it could be done, just that I would find out.
                Thanks.
                • Synthohol
                  • 5888
                  Re: C454e
                  It's impossible to lock out a tray and still be accessible for checks only.
                  I mean you can set a tray for like letterhead or special paper so the auto paper tray switching won't use it unless specified bit you can still select the tray at the panel for copies.
                  Also depending on the checks some have the dotted line perf which is rough and wares out the drum or transfer belt early but there are smooth perf checks which perform better and don't cause Dame but the checks come apart depending on the quality.
                  Unfortunately people have a misconception of the copiers capabilities.
                  It's classified as a plain paper copier that can periodically use special or thick paper for short runs.
                  I still maintain for best results use the bypass and take the bypass out of the auto paper selection.
                  Good luck but I think they will be dissapointed there is no way I know of to lock out a tray from copying but be available for printing.
                    • 14970
                    Re: C454e
                    Locking the tray out for copying is the easy part. I just use the "Panel Customizing Tool". Locking it out from printing is proving to be the difficult part.
                    • Synthohol
                      • 5888
                      Re: C454e
                      is the panel tool on SSD? i never used it and now you have my curiosity up.
                        • 14970
                        Re: C454e
                        I think it is in one stop product support under utilities.
                        • Synthohol
                          • 5888
                          Re: C454e
                          ill have to tinker with our demo room now.
                          thank you sir!
