Error code c2253
  • bunchieattia
    • Aug 2017
    • 4
    [Error Code] Error code c2253
    Hi Guys,
    I have a c360 Konica Mionlta that pops up c2253 when ever I send print in color
    It said the PC DRUM Motor, But I noticed it wasnt the motor but some BOARD, CAN YOU PLS IDENTIFY WHICH BOARD IS THAT ????
  • Synthohol
    Certified Konica Expert
    • 5912
    Re: Error code c2253
    Various error codes, such as C2152, C2253, C3201 and C5102 may be indicated as the MFP begins to run through stabilization. All the errors are drive motor related.
    Solution
    CAUSE: The MFP power supply is failing.
    SOLUTION: Replace the power supply (p/n A0ED M400 03).
    • mdtrinh
      • Aug 2010
      • 68
      Originally posted by bunchieattia
      Hi Guys,
      Are you able to resolve the problem?
      I got a C360 with C2253 at power on, and replace power supply, but problem still the same.
      • mdtrinh
        • Aug 2010
        • 68
        Finally, it turn out to be bad Color PC Motor, just behind controller box.
