Printing from Network to C350 causes printed error code
  • victorgator
    • Oct 2011
    • 8
    [Error Code] Printing from Network to C350 causes printed error code
    C350 that originally came with Fiery controller that recently stopped "Fiering" up.
    Able to access web control panel and Print directly to C350 via IP address through the network, but it only prints the following:
    "%!PS-Adobe-3.0 %APL_DSC_Encoding: UTF8 %APLProducer: (Version 10.13.4 (Build 17E199
    followed by numerous blank pieces of paper.
    Is there any way to print properly without the Fiery? If so, what adjustments do I need to make? Should I just buy a new Fiery?
  • victorgator
    • Oct 2011
    • 8
    Re: Printing from Network to C350 causes printed error code
    Answering my own post here -- installed a Generic PCL Printer driver from Mac and WHAM! It's printing black and white at least! Now -- how to get it to print color?
      check your driver for a "auto color/full/b&w" check box
      • mincopier
        • Dec 2015
        • 289
        Service mode, System 2(?), Controller Type, change back to Type 0. This should then allow both PS and PCL drivers to work using the onboard Empron controller. Of course the Fiery drivers will no longer work. You must use the correct driver.
        • Synthohol
          Certified Konica Expert
          • 5824
          universal drivers are junk.
          Download Centre | Support & Downloads - Business Products | KONICA MINOLTA
          get the real PS/PCL driver.
