C220 USB port
  • paulrid
    • Nov 2011
    • 206
    C220 USB port
    Hi all,
    i have been been to a c220 this morning where the front USB port doesn't seem to be working, when I insert a USB stick nothing happens not even the graphic at the bottom of the screen. It also doesn't show up as external memory from user box, i then tried my movie data file USB in system 2 and nothing. What I don't know is if there's any s/w switches or anything else to disable these ports?
    any info much appreciated.
    thanks Paul.
  • mo0651
    • 1054
    Re: C220 USB port
    USB must be 2.0 or less compatible on this model. I have seen Some USBs work in some models and not in others.
    • paulrid
      • Nov 2011
      • 206
      Re: C220 USB port
      Thanks mo but I'm sure it's not the USB sticks I've tried as there are other c220 at this location which work fine with them.
      paul.
      • Bix
        • Apr 2018
        • 1421
        Re: C220 USB port
        Have you enabled the USB port in Administrator?
        Utility > Administrator > Password > System settings > User box settings > External Memory fuction settings.
        After switch OFF to ON.
        • paulrid
          • Nov 2011
          • 206
          Re: C220 USB port
          Thanks Bix but they are all set to on.
          paul.
          • Synthohol
            Certified Konica Expert
            • 5824
            Re: C220 USB port
            That port routes to the back on the mfp board. Unplug the cable and try the usb direct into the board.
            • paulrid
              • Nov 2011
              • 206
              Re: C220 USB port
              Hi synthohol next time I'm there I'll try that but.
              Thanks Paul.
              • paulrid
                • Nov 2011
                • 206
                Re: C220 USB port
                I was there today and even though last visit I moved the lead from one USB port to the other I didn't try the USB stick in the rear port but as advised today I did and guess what it worked 👍
                I may look at a scrap machine and see where the routing for the front port goes and see how easy it is to change but for the moment they can use a rear port.
                thanks Paul.
