Bizhub Pro 951 ADU Unit won't come out
  • Valintine
    • Jan 2012
    • 147
    Hello
    I have a Bizhub Pro 951 that started with a paper jam. When the customer tried to remove the jam following instructions on the screen the green handle that is used to pull out the adu broke. I have tried to turn the shaft with no luck. I also tried getting to the area from the rear of the machine and hit a wall. Has anyone have any suggestions. All help would be appreciated Thank you in advance.
  • allan
    RTFM!!
    • 5462
    Re: Bizhub Pro 951 ADU Unit won't come out
    Did you unlock the shaft??
    Whatever
      • 30303
      in the front near handle along the front bottom of the ADU there is a little metal tab that will release the lock
      • Valintine
        • Jan 2012
        • 147
        The customer broke the handle trying to remove the jam. I am not able to turn the handle the shaft seems to be stuck. Is there a trick to get it to release?
        • Valintine
          • Jan 2012
          • 147
          I found it. Thank you both for the replies.
          • allan
            RTFM!!
            • 5462
            Its a little funny.
            Whatever
              • 23009
              If it gets really bent up you'll have to do major disassembly of the front of the drawer to reform the latching lock mechanism. I've also seen an enduser shear off the screw for the locking cam in the rear. Maybe I just got lucky, but it only dropped down into the bottom of the machine. I was able to spin out the threaded stub with a small bit and drill, laying under the drawer. =^..^=
              • allan
                RTFM!!
                • 5462
                Had that last week. Was not so lucky, had to cut groove in the shaft to turn it with a flat.
                Whatever
                  • 23009
                  Nice work! That's second choice. With the head broken off, the threaded stub isn't tight. I just needs some encouragement. =^..^=
                  • Synthohol
                    Certified Konica Expert
                    • 5849
                    left handed drill bits are the tits for this!
                    otherwise i carry a file and grind a slot. i really should get a dremmel.
                    • allan
                      RTFM!!
                      • 5462
                      a Dremmel would be a most useful tool.
                      Another thing to carry in the car....
                      Whatever
                        • 23009
                        I have far too much stuff in the car, Dremel included. =^..^=
                          • 23009
