Samples of image problem Bizhub c452
  • chawqi
    • May 2018
    • 20
    Hi everybody
    here is the samples of my copying problem
  • copyman
    Owner / Technician
    • Sep 2005
    • 4723
    Re: Samples of image problem Bizhub c452
    A little more information would help. Does this happen when printing or just copying? What do internal test pages look like? What have you done so far?
    First thing that comes to mind is the printhead / laser unit is bad. If only when copying look at the CCD unit, loose connectors, etc.
    • chawqi
      • May 2018
      • 20
      thanks for your interest
      Here is my history, I have formatted my hard drive and I've got the message of no animation guide data available so I have downlaoded the movie data from the internet but when trying to fixe it in the machine I've got the message cd390, then I've rebboted the machine but it appeared that it has resetted all data, and among problems the imaging unit problem. for more information the printing is very good but the copying is bad.
      thanks
      • Synthohol
        Certified Konica Expert
        • 5848
        those are the lines of shame.
        perform the initial setup step by step as if machine was brand new and the lines will go away.
        • chawqi
          • May 2018
          • 20
          Excuse me could you tell me how to do this because I'm not perfect in this since I'm not a technician but with yours help I can manage to resolve it.
          thank you again
          • Elmo
            • Feb 2010
            • 541
            The reason you have this fault is because you are not a tech
            best advice is to get a qualified tech to fix your machine
            messing around with it yourself can cause more problems than you fix
            I Used To Live To Fix Things Now i Fix Things To Live
            • chawqi
              • May 2018
              • 20
              Excuse me for my interference
              The Technician I have called couldn't resolve this problem
              • Synthohol
                • 5848
                Hope you didn't pay them.
                This is the most basic of all troubleshooting.
                If you still have the books that came with the machine the setup guide is in there as well usually.
                • chawqi
                  • May 2018
                  • 20
                  Not only I payed them but they ask me for more
                  • Elmo
                    • Feb 2010
                    • 541
                    Thats why i advised getting a qualified Tech
                    you are on this site looking for help to fix your machine
                    my advise is to get a qualified Tech
                    but what do i know ive only been doing this for a living for over 30 years
                    • chawqi
                      • May 2018
                      • 20
                      thank you for your help
                      Honestly I managed to resolve problems of my machine I hope to do it with this I need only more help because most of tech I know are dishonest
                      • Elmo
                        • Feb 2010
                        • 541
                        What was the initial problem
                        what pointed you to formatting the hdd
                        was there an error code
                        • Elmo
                          • Feb 2010
                          • 541
                          honestly i managed to resolve problems of my machine i hope to do it with this i need only more help because most of tech i know are dishonest
                          you obviously do not know any of the techs from here
                          • chawqi
                            • May 2018
                            • 20
                            The inial problem was that the machine couldn't print, and I was advised to format HDD, since then I've got problems
                              thank you again
                              why in for gods sake if you are NOT a tech why would you start formatting drives ect without the SERVICE MANUAL?
                              NOW PAY A TECH TO CLEAN UP YOUR MESS.
