BizHub C554e....week of strange issues
  • copyman
    Owner / Technician
    • Sep 2005
    • 4672
    2nd call this week for something strange.
    After you make a copy, print or scan paper will exit than after about a min the blue start button turns orange, no messages or codes. Even though the button is orange machine will still function if you send a print job, etc. When you touch the copy or scan tab button turns blue, after you scan or copy the button turns orange again.
    I was in a hurry just dropping off toner so told them I would be back tomorrow since machine was still working fine. Plus I had never seen this before.
    After I left I got to thinking energy save mode may be set to 1 min but I thought the whole LCD screen also goes out with energy save mode?
    Anyone ever see this?
    Thanks in advance
  • Flash
    • 378
    Re: BizHub C554e....week of strange issues
    The orange indicator usually means the machine needs some attention. One of the paper trays may have had a malfunction and the machine disabled it or some other function like stapling or hole punch. Power off/on and check faulty part isolation in service mode.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4672
      Thanks Flash, I thought of that but anytime I've ever seen a paper tray or option isolated there was message on the screen, something like "stapling currently cannot be used"
      • Desert Rat
        • May 2008
        • 1089
        Does it do this all day or just at certain times? I'm thinking sour power do you have a surge suppressor on the power line?
        DR
        • kingarthur
          • 1344
          Thanks in advance
          at a guess the auto reset is set to "main menu" after 1 min, so the button will turn orange until you select a function button , and yes, you can still print to it
          • copyman
            Owner / Technician
            • Sep 2005
            • 4672
            Thanks King, I think you are right and makes sense. It is on the menu screen so I may change to basic screen instead.
