Jam 31 on Bizhub C754 with FS-535 Finisher
  • t85ster
    • Mar 2015
    • 39
    Just refurbed this C754 we got in from an auction, and upon connecting the FS-535 and powering up for the first time, Jam 31. No paper or dust at PS-1 (finisher entry detection sensor). Nothing showing in the machine's Jam Log! We don't know if this machine had this problem before we got it in, or if its something new. Machine boots up and runs OK with no finisher attached.
  • t85ster
    • Mar 2015
    • 39
    Re: Jam 31 on Bizhub C754 with FS-535 Finisher
    Oops! Never mind. Found lower finisher entry guide plate was shifted to the rear a very slight amount, just enough to block PS1 if you even breathed on it.
    Must have got bent in shipment. Thanks anyway!
    • pedrohash
      • Oct 2024
      • 7
      Hello, I know this is almost 7 years later but I have the same problem on the exact same unit. Was operating it without the finisher for a moment and plugged the finisher back in and now have this error. I'm not sure where the sensor is to clean, any direction here would be very appreciated! Thank you!IMG_8282.jpg
      • Synthohol
        Certified Konica Expert
        • 5888
        can you enable real jam codes? or look in tech rep and see what the real codes are? 31 is a location, not a code
        • pedrohash
          • Oct 2024
          • 7
          I'm not seeing the jam that's currently happening upon turning the printer on in the jam history. The Issue started yesterday but the last jam showing is on the 12th. Here are pics of the first and last jam history pages (apologies for the glare)
          the most recent codes I can see are 3205 and 6633
          • pedrohash
            • Oct 2024
            • 7
            I also just realized that I have a FS-534, thought it was a 535 apologies
            • Synthohol
              • 5888
              i know this sounds silly but i have to ask, was the finisher plugged in while the machine was on? even in sleep
              also 3205 is ps39 exit sensor right above the fuser if i remember
              the 6633 was a adf jam.
              ive seen bridge units blow the board if plugged in while on.
              if thats the case, it happens to all of us in a WTFDIJD moment
              replace the bridge unit was the only cure i had.
              • pedrohash
                • Oct 2024
                • 7
                It's possible it was plugged in while in sleep. Is there a way to test if the board is blown? Thanks for being so responsive!
                • Synthohol
                  • 5888
                  I'm pretty sure it's porked.
                  You can try to replace just the horizontal transport board but honestly there are enough retired RUs out there you should be able to find a whole one cheap.
                  • pedrohash
                    • Oct 2024
                    • 7
                    Got it, I'm looking at replacements. In the meantime do you know a good website/place to get these parts?
                    • Synthohol
                      • 5888
                      sent you a PM
                      • femaster
                        • May 2011
                        • 1519
                        Not too seem overly simplistic, as I don't know your skill level, but did you remember to plug the RU into the finisher? If you fail to connect that cable what you will get is a perpetual jam in the RU, as seen in your picture, that can't be cleared.
                        • pedrohash
                          • Oct 2024
                          • 7
                          Okay I've ordered a new-used fs534 finisher that I've plugged in and am experiencing the same error code. Which makes me think something is going on with the printer? Any help here is much appreciated
