Bizhub C280 error C2554
  • aAandy
    • Apr 2012
    • 370
    [Error Code] Bizhub C280 error C2554
    Hello People
    this is an old machine with over a million prints on it and the client only wants to keep it running til the end of a build job they're doing (another month tops) - i realise this is a magenta problem, so i checked State Confirmation - Level History and while all the other colors showed around the 6% mark, magenta showed around the 10% mark
    is it just depleted dev? any pointers would be very much appreciated
    thanks in advance
    Andy
  • copyman
    Owner / Technician
    • Sep 2005
    • 4677
    Re: Bizhub C280 error C2554
    Did you recently change the magenta drum? Sometimes when the drum is changed or re-chipped it crashes the developer. Especially if the consumable life counters are turned off and consumables are way over life. You customer will have to bite the bullet and replace the mag unit if they want to continue using it
    • aAandy
      • Apr 2012
      • 370
      nothing was recently changed and life counters are on - from memory the drum units were re-chipped a year ago but it has been printing fine til this error popped up,,, cyan dev is slightly depleted (very faint diagonal banding) but no such banding on magenta, which is producing a lovely solid with no backgrounding
      i've seen similar problems before, but in those instances "level history' showed 3%, not 10%
      replace the developer is the solution?
      • Woxner
        • Jul 2011
        • 847
        if the cyan is banding from depletion you will need to change both. i have seen these pull even if life has not been met.
        • Woxner
          • Jul 2011
          • 847
          should mention you should change the drum too or it might pull again
          • copyman
            Owner / Technician
            • Sep 2005
            • 4677
            Good points wox. Forgot that the drum should be changed at same time as new developer. Last thing you want is a bad drum to pull the developer out of a new unit.
            • aAandy
              • Apr 2012
              • 370
              thanks for your responses gents, but the magenta dev is not being pulled, it prints perfectly - the cyan dev is only just showing the faintest signs of diagonal banding and they will put up with that for a month
              just wanted to make sure it was the dev that's sick, not some toner supply issue - i imagine that the level history for magenta showing 10+% is indicative of the dev being bad (not depleted)
              can either of you confirm?
              • allan
                RTFM!!
                • 5462
                Try this.
                Block the toner port and run 20 halftones(255) then short out pin 1 and 5(ICP) on the dev tank connector while its plugged in an make the door switch for a second and a bit. That will reset the devtank and initialize the dev.
                Then for the depletion add DV116(yes its black) until the mag roller is covered and do the same to reset. Then run half tones(255) until the black toner is worked out, that will take around 200 to 300 print.
                Bobs your uncle.
                Whatever
                • Boltaction
                  • 92
                  Originally posted by allan
                  Try this.
                  Bobs your uncle.
                  I have had luck with running magenta (or whichever color the code is pointing to) gradations until the TCR levels returns to sub-8% depending on how high the level was before.
                  Anytime I've seen one at 12% or above it signaled a developer/drum/high voltage issue. I've debated keeping the Life Stop setting ON specifically for this issue, but could cause me headaches in the field having to replace good drum units.
                  • aAandy
                    • Apr 2012
                    • 370
                    many thanks gentlemen - i will try your suggestions
                    • floody
                      • Mar 2017
                      • 37
                      are you using genuine toner?
                      • aAandy
                        • Apr 2012
                        • 370
                        the solution was a new ITB cleaner blade
                        it was not cleaning the calibration marks correctly, leaving a slight smudge which resulted in wrong readings, hence the high M toner density level reading - fitted a new blade, ran gradations and she came good
                        thank you all for your assistance, very much appreciated
                        • Boltaction
                          • 92
                          Following up to see if your issue has been resolved.
                          • srvctec
                            Former KM Senior Tech
                            • Oct 2009
                            • 827
                            See the post directly above yours.
                            Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                            • Boltaction
                              • 92
                              Dang. Well, I thought I could read... These copiers are making me lose my mind.
