C454e series "Memeory Overflow" errors
  • BHM
    • Feb 2011
    • 131
    Have a customer getting erratic "memory overflow" errors when scanning to smb. Scanning to a 2012 file server with plenty of hard drive space available, scan folder is empty. Ended up bringing them a loaner and it has the same problem. Really erratic. Can not find much info on memory overflow. Scan error log shows scan error 0 which is not a real scan error code.
    Any thoughts?
  • Synthohol
    Certified Konica Expert
    • 5892
    Re: C454e series "Memeory Overflow" errors
    Check the HDD state in service mode. Should have like 170Gb free space.
    Anytime I ran into that it was the copier hdd not the destination.
    You can backup the machine (soft sw 72 change to hex 04) and in admin mode page 2 there is backup to usb. Select all make a password of 1 or something very simple and plug a 4G or smaller usb in the front panel.
    Back ot all up then do a logical format not physical.
    Then reenable hdd if needed and load movie data. Then restore the da at a you backed up.
    Good luck
    • BHM
      • Feb 2011
      • 131
      Had 131Gb free on their original machine that is currently in our shop. The loaner that is there is also having the same issue but I have not looked at the free space on that one.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4765
        Agree with Synthohol . Backup and do a logical format. The HDD in kon/min is primarily used for scanning.
        • BHM
          • Feb 2011
          • 131
          We will try that but both machines (original and loaner) work fine at our office and both have the issue at the customer's office.
          • Synthohol
            • 5892
            Did you try scanning to your laptop?
            Also make sure SMB v2\3 is enabled in network settings on copier.
            I would plug in my laptop to their network and scan like 100 pages to it and see if there are any errors.
            If not it could be a security/protocol/quota issue on their server but I still have only seen that error when the copier hdd is acting stupid.
            • BHM
              • Feb 2011
              • 131
              Set her up to scan to her computer directly instead of the server. Two days now and no problems yet. Going to give it a few more days and have their IT person look at the server again since we "proved" it was not our device.
