8 series drum life
  • REGSIS
    • May 2016
    • 434
    Re: 8 series drum life
    Originally posted by larweedad
    I had one that showed the lines at 2 % life left.
    I had one DR512 CMY drum at 35% life left that sucked out cyan developer. Burned charge corona and matted drum surface at 4 places, 2 at front 2 at back. Transfer belt burned at same spots, black drum matted also but much less. Black drum charged corona not burned - life 65% left.
    All OEM parts and toners. Everything inside manufacturer's life.
    Has anyone experienced this developer sucking on 8 series yet?
    Since there's no charge corona, is a charge roller a solution to this issue?
    • Tech Helpdesk
      • Jul 2015
      • 112
      We are experiencing toner sticking to the drum surface around 50% of life and we also are getting white lines caused by toner getting stuck on the charge roller.
      Is anyone else getting these problems ?
        • 14513
        OEM toner?
        • Tech Helpdesk
          • Jul 2015
          • 112
          #19
          OEM toner?
          We have some customers on OEM and some on compatibles.
          • Bix
            • Apr 2018
            • 1421
            #20
            I have recently replaced in a bizhub 458 (DR-313K).
            The manual indicates the replacement every 155,000 copies. The printer started making bad copies at 140,000 (horizontally).
            The printer warned me in advance with the monitoring software (first call). The MFP did not alert the customer to the screen. (I guess because there are still 140,000 copies).
