8 series drum life
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    [CQ] 8 series drum life
    Can they be extended, yes or no?
    I already know the answer from my own experience, having to keep them in the car and change them for customers for "lines on print" on a regular basis.
    However being told "its not happening anywhere else" is the usual reply.
    So, "is it happening anywhere else?"
    • 23010
    Re: 8 series drum life
    They seem to be making the manufacturers quoted yield ... just barely. Not twice to three times the stated yield like the e series. The major difference is the change from charge wires to charge rollers. It must be the physical contact that makes the difference. =^..^=
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      This is also my experience.
      Hopefully some more people can add their experiences too.
      • allan
        RTFM!!
        • 5462
        Just gets past yield.
        Whatever
        • rrrohan
          • Sep 2011
          • 1977
          Least the yield is correct. We are so use to drums exceeding life we almost expect it now so when it only manages maybe 110% we fill ripped off.
          • Woxner
            • Jul 2011
            • 854
            pretty much advertise yield . once in awhile you get lucky and it goes longer
              • 15017
              We average about 1000 over advertised yield. Better than not making it to yield I guess.
              Changing from a charge corona to a charge roller is the direct cause of this, and the only reason KonMin made the change as far as I can see. They give some phony ozone reduction reason, but getting $200 every 100k instead of every 200k is the real reason.
              • Bix
                • Apr 2018
                • 1421
                • allan
                  RTFM!!
                  • 5462
                  Mmm does a DR512 fit in there?
                  Whatever
                    • 23010
                    Primary charge voltage will be significantly lower for a charge roller than a corona wire. I would expect black copies (assuming you could make it fit). =^..^=
                    • Kidaver
                      Ghoulscout
                      • Apr 2011
                      • 912
                      Yeah all this changing to charge rollers for ozone tree hugging green stuff has just made drum life awful. Also you can't really pop these rollers out like on a Kyocera and clean all that built up paper dust that accumulates on them due to cheap paper.
                      "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
                      • larweedad
                        • 93
                        I had one that showed the lines at 2 % life left.
                        • AjitN
                          • Mar 2009
                          • 287
                          TO extend the life, frequent cleaning of charge roller is the only option, which depends upon quality of paper and environmental conditions.
                          • Brett GS
                            • Jun 2013
                            • 154
                            Havent been that lucky to get them to run over life,had many fail long before they were due.
                            • jamesyboy
                              toner monkey
                              • Jul 2010
                              • 188
                              you can modify a k drum to fit for a colour which takes the cost down
                              and yes its the charge rollers
