Konica C452 scan/fax not showing up
  • wild140
    • Feb 2017
    • 70
    [Misc] Konica C452 scan/fax not showing up
    This occurred after doing an all clear .
    Not sure what got disabled . The button just beeps . The fax board is "set" .
    Greatly appreciate the assistance
  • antone
    • Oct 2014
    • 344
    Re: Konica C452 scan/fax not showing up
    System setting forward to page 2 register key setting hard key Key 1= Fax_Scan.......check these settings ok
    Sent from my SM-N950U using Tapatalk
    • antone
      • Oct 2014
      • 344
      Power down for 15 seconds...ok
      • wild140
        • Feb 2017
        • 70
        System setting under Administration page 2 I do not see Register Key .
        System setting (1) in service mode I do not see page 2
        System setting (2 ) page 2 , I do not see Register
          • 30291
          Chech to see if hhd is set
          • Dickie
            • Nov 2011
            • 190
            I'm with the above. It needs to know that it has a Hard Drive to allow these functions and full reset usually sets this to off
            • wild140
              • Feb 2017
              • 70
              Thank You very much that was it.
              One other question . The unit had the old vendors logo pop up . I deleted that info but now I am getting a message on the unit that says " no animation guide available. Thankfully It does not effect any functionality. How do I get rid of that message ? I can not find where in the unit I deleted the panel file
              • guitar9199
                • Sep 2016
                • 1100
                "No Animation Guide" means the Movie Data file is missing. It needs to be re-flashed.
                • wild140
                  • Feb 2017
                  • 70
                  Just to be clear , Update Firmware ?
                    • 30291
                    I believe you can just get the missing firmware. Don't have to install it all. Usually you can only get it from a dealer.
                    • Reed
                      • Feb 2011
                      • 258
                      It's a movie data file. It's separate from the firmware
                      • wild140
                        • Feb 2017
                        • 70
                        I have the latest firmware , Just wanted to clarify that is what you meant , Thanks Again
                        • Synthohol
                          Certified Konica Expert
                          • 5846
                          firmware and movie data are 2 different files.
                          and loaded 2 different ways.
                          • wild140
                            • Feb 2017
                            • 70
                            Can I upload the Data Music file from another unit ?
                            The unit has one other anomaly when printing 4 up it sometimes will shrink one of the images to postage stamp size ( see attached) C452.pdf
                            According to the end user this was one file but only the first page did this and after two tries it corrected itself .
                            • copier tech
                              • 8169
