C554e cycles on and off.
  • GR81
    • Jun 2012
    • 45
    We have a C554e that when turned on will start the boot up for 2 seconds then turn off and then start all over again.
    Anyone run into this before?
  • avecosat
    • Jun 2012
    • 305
    Re: C554e cycles on and off.
    Is the SSD , the 4 series has this problem .
    • Max
      • Oct 2011
      • 557
      I hope I got the correct model range. SSD needs to be version 6.05 and the latest firmware. If it is then replace ssd.
      • GR81
        • Jun 2012
        • 45
        It was the SSD, thanks a ton for the help!!!!
        • copier tech
          • 8144
          Where did you get an SSD board in 6 hours after reporting this issue!?
          โ€‹
          • GR81
            • Jun 2012
            • 45
            From another C554e we are parting out.
            • Synthohol
              Certified Konica Expert
              • 5824
              just curious, did it carry over the meters from the parts machine?
              • copier tech
                • 8144
                This is why I asked never fitted a used SSD only new!
                โ€‹
                • GR81
                  • Jun 2012
                  • 45
                  Yes it did, along with all it's other settings.
