Bizhub 4 non e series Control panel
  • delboy10
    • Jun 2010
    • 43
    Hello all,
    I have a Bizhub C224 non e that throw a code C-D411 and I found where the problem is. It is the ribbon cable that connect the control panel PCB to the keypad and sub power part. Please see the attach pictures. I know I have to replace the Control Panel but it is quite expensive for the worth of the machine. Just wonder any of you run into this before. Were you able to locate and replace the ribbon cable? And would a 4e panel work with the firmware that update the 4 to 4e? Thank you all!
    delboy
  • Albonline
    • Sep 2008
    • 1150
    Re: Bizhub 4 non e series Control panel
    e panel will work , no hard keypad though.
    • delboy10
      • Jun 2010
      • 43
      Hello and thanks for replying. Would you able to share how you get it to work? I was in contact with Hytec Dealer Services to inquire about the repair of the panel. I talked to one of the tech and he told me 4e panel may work on 4 and he would try to see if it works. He did try and told me it did not work for him. However, he did not know there is a firmware to convert the 4 to 4e. Did you have to update firmware first to get it to work? I do not have anything to try at the moment. Thank you!
      delboy
      • copier tech
        • 8144
        There is firmware to convert a non 'e 'to an 'e' however it only gives some of the 'e' functions, it doesn't actually "convert" the machine as such.
        • jonbonse
          • Jun 2009
          • 737
          Originally posted by delboy10
          Hello all,
          delboy
          Hi, I have this exact issue.,.... did you manage to source a ribbon cable?
          • rrrohan
            • Sep 2011
            • 1977
            Did you test continuity on cable?
            Sent from my SM-G955F using Tapatalk
            • jonbonse
              • Jun 2009
              • 737
              • delboy10
                • Jun 2010
                • 43
                Hello,
                Unfortunately, I could not find the ribbon cable. Anyway, I don't know if it would help but I can confirm you can use the 4e control panel for the 4 series with updated firmware to emulate the 4 to 4e. You also need new cable to connect to the Main board (because of the length). The firmware would have to be done to use the on display number keys instead off the keypad.
                delboy
                • SimoneCariz
                  • Jan 2018
                  • 7
                  hi!
                  The kit replace cable is a code
                  9981000545 - NEW FCC KIT
                  DisplayC224SostituzioneFlatCable.pdf
                  good work!!
                  • delboy10
                    • Jun 2010
                    • 43
                    Originally posted by SimoneCariz
                    hi!
                    [ATTACH]40592[/ATTACH]
                    good work!!
                    Thank you so much for the information! However, it is not available in North America Market!!!
                    delboy
                    • jonbonse
                      • Jun 2009
                      • 737
                      hi!
                      good work!!
                      PERFECT Thankyou!
                      • Gift
                        • Mar 2011
                        • 2459
                        delboy
                        perhaps you need to request it at your KM product support contact
                        • korthr5
                          • Feb 2016
                          • 39
                          delboy
                          Hello
                          In europe has already been discontinued
                          Regards
