Bizhub 227 does not print until it receives the whole file
  • Bix
    • Apr 2018
    • 1421
    Hello,
    lately I have a problem with large PDFs (1,000-3,000 pages) with Konica Minolta.
    In short, as long as the printer does not receive the whole file, it does not print.
    The problem occurs in all the bizhub 227 that the customer has. Also I have tried in the office with a 258 and 364e and actually I also have this problem.
    In the driver's print settings, it is already set to "Print immediately".
    I have already tried with PCL and PostScript but the problem persists. Did any of you have a similar problem?
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: Bizhub 227 does not print until it receives the whole file
    Originally posted by Bix
    Hello,
    Typically the postscript would be your fix. Are you printing locally on pc or thru server?
      • 30165
      Hello,
      What the port setting? Should tcp ip port raw 9100
      • Bix
        • Apr 2018
        • 1421
        I've found this problem from multiple customers on different networks.
        I fear that it is the fault of universal drivers and/or Adobe Acrobat
        • Woxner
          • Jul 2011
          • 848
          dont use universal driver they suck... also try and set in network of machine under details the speed set to 1GB its helped my on this.
          • tech51
            • 846
            • copier tech
              • 8142
              What version firmware are the machines on? often issues are covered in fw updates.
              • Bix
                • Apr 2018
                • 1421
                Hi, I doubt the problem is due to the firmware.
                I have tried on a bizhub 227, 4052, c258, c364e and all have the same problem. To verify, I tried to print a PDF of a SERVICE MANUAL Konica Minolta.
                Originally posted by tech51
                Make sure that the collate button isn’t ticked anywhere. .
                What do you mean?
                • Bix
                  • Apr 2018
                  • 1421
                  Hello, maybe there is a breakthrough for bizhub 4052:
                  1. I have reinstalled Adobe to get the latest update.
                  2 I downloaded the specific PCL6 drivers.
                  Now the problem is not there. It is only available with PostScript and universal drivers. I also discovered that this problem is only with duplex pages. If they make a single page, it starts immediately. Has anyone ever found?
                  • Bix
                    • Apr 2018
                    • 1421
                    Resolved! That's how:
                    In PCL drivers, you must go to Printing preferences> Finishing> Paper availability: Productivity priority.
                    This speeds up the start of the first print a lot.
                      What do you mean?
                      he means in the PRINT DRIVER...make sure collate isn't checked
                      • Bix
                        • Apr 2018
                        • 1421
                        Thank you Phil!
                        I have resolved in this way
