bizhub C33851fs
  • 3ktlc
    • Feb 2018
    • 180
    bizhub C33851fs
    While the machine is pushing a set of papers to the exit tray, the next one is coming in. Sometimes, it doesn't stack correctly or causes a jam. Anyone see this before?
  • copier tech
    • 8132
    Re: bizhub C33851fs
    Most likely damp paper causing this issue especially if the prints come out a bit curly.
    • Albonline
      • Sep 2008
      • 1144
      Re: bizhub C33851fs
      have one doing the same thing here. suspect the dup unit isnt moving the first sheet of the set fast enough to clear in time.have had it crumple paper under the fuser a few times.
      • 3ktlc
        • Feb 2018
        • 180
        Re: bizhub C33851fs
        Now this machine won't even run 1 sheet. It jams right at the exit. Any ideas on this?
        • Albonline
          • Sep 2008
          • 1144
          Re: bizhub C33851fs
          try stapling. if it works then i would be looking at things that could slow down paper travel, eg motors clutches gummed up bushings.
          • 3ktlc
            • Feb 2018
            • 180
            Re: bizhub C33851fs
            Nope. Still jams at exit
            • 3ktlc
              • Feb 2018
              • 180
              Re: bizhub C33851fs
              Turns out it was a couple of problems
              Exit actuator was broke.
              Rails in finisher were bone dry causing the guides to struggle to move.
              Only 21k on this machine.
              • Albonline
                • Sep 2008
                • 1144
                Re: bizhub C33851fs
                same problem here, dry rails causing finisher to slow. I am trying plus guard on one and dry surf on another. either way lub is the fix.
                • 3ktlc
                  • Feb 2018
                  • 180
                  Re: bizhub C33851fs
                  Yep. Lubing the rails is the fix. Just had another one start that. Lubed the rails and started working again. Going to be part of the regular maintenance on this machine
