C3bo3. Konica Minolta. Bizhub 558e
  • brent
    • Nov 2008
    • 1214
    900 copies. Brand new machine. This has codes out twice. The book said it was not receiving the signal
    from the fuser yada. Has anyone corrected this with a new fusing section?
    thank you so much
    brent
  • antone
    • Oct 2014
    • 344
    Re: C3bo3. Konica Minolta. Bizhub 558e
    Brent got the same error.....any fix for this problem?
    Sent from my SM-N950U using Tapatalk
    • brent
      • Nov 2008
      • 1214
      we reset it twice its working don't jinx me lol
      I did download a new updated firmware for my next visit if it continues to fail
      keep me in the loop as we need to figure out a positive fix for this werid code
      brent
      • antone
        • Oct 2014
        • 344
        Thks alot....their a bulletin on Monica web site with something close to error! Power save mode ....turn it off......I guess I will see lol
        • antone
          • Oct 2014
          • 344
          Firmware upgrade need ....will do the job......new one just came out
          • Woxner
            • Jul 2011
            • 850
            install v1 firmware. this got triggered from a lampcode from the scanner if you look at the history on the print out you will see it.
            • KMFLT3CH
              • May 2017
              • 241
              There is a new bulletin for this C-3B03 code, see pdf below.
              11380.pdf
              C3B03 Error Code Troubleshooting.pdf
              • antone
                • Oct 2014
                • 344
                Upgrade to special firmware
