Replace DV - same error code. What does the 03 code exactly mean? I'd rather not change the TDS unless I have to. It wont let me calibrate the DV either. I've cleaned the machine really good. Any ideas? I'm not really familiar with Konica machines.
F-26-03 Konica 7145
F-26-03 Konica 7145
Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!". -
This can be caused by the TDS going bad or even the harness being trapped and grounded...check the harness on the dev unit!Please do not PM me without asking first.Comment
redime
Yup, can be a pinched or poorly operating TDS, can also be a bad TCSB on the drum unit - can be a flipped blade, M1 motor having a bad solder point -- and can even be the board.Comment
PROBLEM:
Door message, code 0003 with F26-03 code.
Content CAUSE: Thermistor was shorted out, causing relay 1 on the power supply to trip. This results in the loss of 24v to front door switch and boards.
SOLUTION: Replace the Thermistor ( p/n 26NA88011). TH1 and TH2 are on the same harness.
Solution provided by Don St.Onge - SSD Windsor.Comment
PROBLEM:
Solution provided by Don St.Onge - SSD Windsor.Please do not PM me without asking first.Comment
I don't really get the reluctance to change the TDS as that is what the error points to; But you may want to remove the toner hopper and clean it out thoroughly make sure it works properly, also make sure all HV ( Ch and T/S are working ) then do another dev change and see if L detect will run. But honestly the TDS is much cheaper than Developer.Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
Now into Ip TV KODI BoxesComment
F-26-03 Konica 7145
think its the motor controller board. motor wont turn but its a good motor. will let you know how it turns out. thanks guys, for all your help. hope I can return the favor somedayLife should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".Comment
F26-03 Error
The toner density sensor (TDS) has failed to detect ripple output of 0.5 volts.
You have many areas this could be in, but it most likely to be the TDS sensor if you have already changed the dev. Do a quick check to see if the main dev mag roller is turning by cleaning the dev off one end (don't remove it, just push it into the middle a bit and stick it back in then start up the machine and see if the clean area is covered over with dev again when the error code shows up.
If it is covered over again with dev then the dev is turning.
You should be then looking to change the TDS.
Or if this fails and espceially on older or high volume machines you could be looking at the dev unit bushings getting clogged up with toner and slowing down the dev unit speed causing a lower voltage output. This will require a lenghty and laborious strip down and clean-up of the dev unit or a complete dev unit replacement.
If it isn't turning you should check the driver board to the right of the main/system board. This board provides the power to the motor that drives the dev unit and it is very common for one of it's fuses to fail (especially the one that powers the paper feed motor). With a multi-meter check any component on the board marked with the letters ICP (Integrated Circuit Protecter). An example would be (ICP7, ICP4) there is about 13 or 14. These are basically small fuses which you can buy in any decent electronics shop and can easily replaced with a soldering iron and a pair of pliers.
If all this fails your looking at the motor or the main system board (OACB)Comment
