Bizhub 223 cd001
  • afterhours
    • Mar 2017
    • 152
    Bizhub 223 cd001
    Hello everyone,
    What is this code for and how can I reset it? I can't find it anywhere.
    Thank you for any help you can provide.
    Im a Loser Baby!!!
  • copyman
    Owner / Technician
    • Sep 2005
    • 4765
    Re: Bizhub 223 cd001
    I don't see code either but I would think being a "CD" code it would be related to the RAM, Fax or HDD. I would reseat or swap the RAM and format the HDD. Might have to do a "physical" format on the HDD. Also would try UNsetting the fax and turn machine off and on. Or if fax was removed it may still be set and you have to turn it off (UNset it in service mode "option board status")
    • larweedad
      • 93
      Reformat or replace hhd run logic not physical
      Sent from my SM-N910V using Tapatalk
      • Synthohol
        Certified Konica Expert
        • 5892
        do a logical format and if that fails replace the HDD. its a HDD code thats all.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4765
          With this being a "CD-xxx" code not in the manual I was thinking do physical format and start fresh. Agree it wouldn't hurt to do the logical first. It really doesn't take that much longer with physical that is why I use both formats when odd code or weird issues. 99% of the time only logical necessary.
          • srvctec
            Former KM Senior Tech
            • Oct 2009
            • 827
            Originally posted by copyman
            In this case I would do a Physical format then do the logical. Just going to take longer.
            But if logical works, the OP may not need to spend the extra time running the long process of the physical format. Why do the most "severe" option first?
            Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
