Konica Minolta C 280 Address Book doesn't show up
  • mearmi
    • Oct 2010
    • 350
    [Misc] Konica Minolta C 280 Address Book doesn't show up
    Konica Minolta C 280 Address Book doesn't show users and also in Direct input email icon is missing.
    Formatted all the destinations and registered the new users but still doesn't show up.
    Please advise Thanks
  • mo0651
    • 1054
    Re: Konica Minolta C 280 Address Book doesn't show up
    Check the HDD, is it uninstalled?
    • allan
      RTFM!!
      • 5462
      If its scan to email it could be that SMTP is not set to on.
      Does it show the scan registrations in PSWC?
      Whatever
      • kingarthur
        • 1399
        Has scan to email been turned on/off
        • mearmi
          • Oct 2010
          • 350
          Yes it shows scan registrations in PSWC and HDD is installed.
          • mearmi
            • Oct 2010
            • 350
            Yes it is installed
            • mearmi
              • Oct 2010
              • 350
              It is on
              • allan
                RTFM!!
                • 5462
                Do firmware...
                Whatever
                • emujo2
                  • Mar 2017
                  • 1579
                  There is an obscure setting called scan to authorized folders. If this is on, the only thing that is displayed in the scan screen is Fax numbers. This setting works with AD and SMB scanning to only allow scan to mail and home if these are attributes in AD. If you have any form of authentication set to on, you may also want to check what permissions are set for the logged in and public users. Emujo
                  • rrrohan
                    • Sep 2011
                    • 1977
                    Originally posted by mearmi
                    It is on
                    Agreeded. Physically installed and turned on in service mode are 2 separate things
                    Ive lost scan features after doing initialize all as it had HDD set to npt installed even thought its physically installed.
                    Not insulting your intel OP but if we gloss over this we may be chasing our tail if this ends up being the fault
                    • mearmi
                      • Oct 2010
                      • 350
                      Do firmware...
                      Can anyone send me the firmware and movie file.
                      Thanks a lot
                      mearmi@hotmail.com
                      • Synthohol
                        Certified Konica Expert
                        • 5922
                        pm sent.
                        • emujo2
                          • Mar 2017
                          • 1579
                          You can register users, but they don't show up in the address book and direct input option is missing...How is firmware going to resolve this?? This is a admin setting that has been turned on. If you really can't take the time to find the cause, a factory reset will help more than firmware. At least the admin settings will be returned to their default values. Emujo
                          • allan
                            RTFM!!
                            • 5462
                            I have had cases where the firmware was corrupt and stuff does not show up.
                            Try to initialise network settings?
                            Whatever
                            • Synthohol
                              • 5922
                              Need to verify HDD is set to installed as well as that's where the address book is stired.
