Data Noise issue
  • rockboy69
    • Aug 2018
    • 9
    Data Noise issue
    hi
    i'm having an issue with my KM c6000L
    when i print via the E-100 fiery V9.0 my print out has a lot of digital noise like its not processing my data
    i'm printing via pdf
    the steps i have taken to solve this issue
    -replace cable from fiery to copier
    -reinstall fiery and patches
    -checked main body consumables and lasers (printed color charts from main body they output 100%) internal from fiery all broken data on print image
    page isnt allowing me to upload pre and post print images
  • Albonline
    • Sep 2008
    • 1153
    Re: Data Noise issue
    Originally posted by rockboy69
    hi
    try the cic interface card, reload software after changing.
    • Synthohol
      Certified Konica Expert
      • 5892
      Try reseting the ram stick in the fiery and make sure the cpu HSF is secured.
      Also take a job from the printed queue and select process and hold then go in the hold queue and preview the document. If it's broken up there it's likely a fiery issue. If it looks good then likely it's the video interface as suggested or does it have the big HDD accessory? Maybe they need reformatting.
      Usually if the fiery is good it will rip the file perfect which you can see in preview.
      Good luck.
      • rockboy69
        • Aug 2018
        • 9
        Good luck.
        hi thanks for the reply
        the machine does have the big HDD unit mounted on the back with 6 HDD's are you able to give me more info in its purpose
        will check the RAM and the Processor to make sure everything is in order
        • rockboy69
          • Aug 2018
          • 9
          have checked all the components suggested
          everything seems to be in working order i have also added ferrit cores to the fiery-copier cable but now am getting a c6703 error when i send a job
          but i did notice one of the HDD cables with slight damage to the insulation i tested with a multi meter but all the pins are giving me good continuity
          • Albonline
            • Sep 2008
            • 1153
            • rockboy69
              • Aug 2018
              • 9
              hi all thanks for all the help
              i'm still having the issue it was suggested from other forums to format the HD-514 (with 6 hard dives) but noone has detail on how to do it
              i just wanted to know if it is possible to format the HD-514 unit on back of the printer, if so how is done and what's the default format (FAT32 or NTFS)
