Kyocera Taskalfa 6550ci exit unit motor stalls
  • carolscurriculum
    • May 2017
    • 39
    Hello I have a Kyocera Taskalfa 6550ci jam code 4211 I found that the exit unit motor stalls I replaced the motor same problem it spins until the paper hits it then stops. could it be a wiring harness or board?
    Re: Kyocera Taskalfa 6550ci exit unit motor stalls
    could be a sensor
      • 23008
      Do you see any 4911, 4912, 4913, 4914? =^..^=
      • carolscurriculum
        • May 2017
        • 39
        could be a sensor
        checked the sensors and narrowed it down to the exit motor I found that the exit unit motor stop when the paper hits it EVEN STARTS AT ALL I replaced the motor same problem it spins until the paper hits it then stops. could it be a wiring harness or board?
          31 years in the industry has taught me NOTHING is impossible when it comes to equipment .
          yes very possible it could be a harness or board. pinched wires can cause ALL SORTS of issues.
          • carolscurriculum
            • May 2017
            • 39
            I just swapped the whole unit exit from another printer same issue I'm thinking its a board issue.
              well now by process of elimination I do believe you are correct.
              • carolscurriculum
                • May 2017
                • 39
                Now which board engine pwb or front pwb
                  not knowing that unit.. i would say which ever board that assm plugs into...check your PtP in service manual
