konica minolta c451
  • karimharaka
    • May 2012
    • 11
    konica minolta c451
    Hello,
    i need help pleas, i have a c451 konica minolta it s work well but when i make a phoyocopie ftom the scanner direct it print a small squares on the paper i tried many solutions but nothing works
    Re: konica minolta c451
    Originally posted by karimharaka
    Hello,
    i need help pleas, i have a c451 Konicka Minolta it s work well but when i make a photocopy from the scanner direct it print a small squares on the paper i tried many solutions but nothing works
    Tech or end user?
      • 23002
      Perhaps you'd like to attach a sample? =^..^=
      • greglogston
        • Jul 2018
        • 34
        You might wanna go through the installation instructions again. Sounds like that machine is back at factory settings or something.
        • mincopier
          • Dec 2015
          • 289
          The machine has lost it's setting and the initial set up must be done again. This should be done by a qualified technician.
          • karimharaka
            • May 2012
            • 11
            thank you for your reply. i have changed the NVRAM how can i programe it again ?
            • greglogston
              • Jul 2018
              • 34
              Not helping you as I can see that you are not a qualified technician and you didn't take our suggestions.
              • karimharaka
                • May 2012
                • 11
                Hello sir,
                i would like to inform you that i had changed the nvram in order to give you more information about the problem
                so knwo what are the instructions should i follow to solve this problem?
                • Synthohol
                  Certified Konica Expert
                  • 5809
                  why would you change the NVRAM?
                  • mincopier
                    • Dec 2015
                    • 289
                    Hello sir,
                    Check your private messages
                    • karimharaka
                      • May 2012
                      • 11
                      because the machine would not started until i changed the NVRAM
