C6500 Softswitch
  • afterhours
    • Mar 2017
    • 152
    C6500 Softswitch
    Hello everyone,
    I'm have a new customer with a c6500. I can't get the machine to do a auto drum potential adjustment. The machine will quite literally sit there adjusting for 24hours straight till I stop it never throwing a code. I looked in the sc history and noticed it has not coded since May. This got me thinking, a few years ago, I followed another tech with a similar situation and found that he had managed to turn on a softswitch that disabled the ability for the machine to malfunction. However, I did not write it down. Does anyone happen to know what that softswitch is. Please help....
    Thank you in advanced.
    Im a Loser Baby!!!
    Re: C6500 Softswitch
    Originally posted by afterhours
    Hello everyone,
    more than likely it was a switch to ignore SOME error codes ... what are you trying to do, disable the drum/fuser/belt/toner message?
    to disable CRITICAL errors from stopping a machine is INSANE! you are just asking for more issues. Figure out what is kicking the code and fix it.
    • afterhours
      • Mar 2017
      • 152
      Thank you. I'm trying to figure out what was disabled prior to my working on this machine. I'm almost 100% certain something with regard to auto drum.potential was disabled but I dont know what.
      Im a Loser Baby!!!
      • afterhours
        • Mar 2017
        • 152
        If I turn the machine on and try to get it to come to ready all it does is sit and say "please wait Now adjusting"
        Im a Loser Baby!!!
          • 22929
          I can tell you this much: I had a machine doing this and it turned out to be a potential control error related to developer density. Entirely by accident I changed the correct developer and it worked for 30K or 40K, then happened again. After 3 or 4 of these developer changes that machine ended up getting replaced, so I can't tell you the full cause.
          Maybe you can get further than I did. =^..^=
          • methogod
            • Dec 2008
            • 915
            reload fail safe firmware, and start from ZERO.
            • afterhours
              • Mar 2017
              • 152
              Good suggestion. Will firmware put all the softswitches back at zero?
              Im a Loser Baby!!!
              • afterhours
                • Mar 2017
                • 152
                I mean default
                Im a Loser Baby!!!
                • methogod
                  • Dec 2008
                  • 915
                  should be a fall back firmware that bring it to normal. i would run you a print out to compare, but i have a C6501, not a c6500.
                  my guess is there used to be a key-card or security device and now its looking for it to ready, but not sure.
                  Can you ready the machine in service mode? to get some test prints out...
                  • afterhours
                    • Mar 2017
                    • 152
                    I found the problem. Softswitch 11-0 was on. It needs to be off. Right away the machine coded with c4520. Now I can troubleshoot.
                    Thanks for all the advice
                    Im a Loser Baby!!!
                    • Toxic
                      • 694
                      How did you get idea for that specific dipws and what is function of it?
                      Just curious.
                      • afterhours
                        • Mar 2017
                        • 152
                        Just curious.
                        I remembered that a couple years ago I followed another tech and when I came to the c6500 it was just saying please wait now adjusting for as long as you left the machine on with out coding. After a couple weeks of working on it and research I ran into some info that spoke about a softswitch that turns most errors off but can cause the machine to cycle that way. Unfortunately I never wrote it down thinking is never run into it again.
                        I am thrilled to have found it again and it will remain in my notes for good.
                        Im a Loser Baby!!!
