BH364e contol panel
    • 14725
    BH364e contol panel
    Does anyone know if the control panel from a BH364e will work on a C364e? I realise the part numbers are different, but KonMin will sometimes put different part numbers on parts that are the same.
  • srvctec
    Former KM Senior Tech
    • Oct 2009
    • 827
    Re: BH364e contol panel
    No clue but curious.
    So, are you going to try it and let us know?
    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
    • acusso1234
      Tecnico
      • Dec 2008
      • 250
      Yes, they are. No firmware required. Done that from a donour C224e to a 224e
      ... In the minute that you're thinking of giving up, think about why you lasted so long ...
      • copyman
        Owner / Technician
        • Sep 2005
        • 4701
        Good to know thanks.
        • srvctec
          • Oct 2009
          • 827
          I wonder if it makes a difference putting a color machine's control panel on a b/w vs. the opposite like the OP was inquiring about. My only thought is that maybe the color panels have extra stuff the b/w machine doesn't need so it works OK but if the b/w panel is missing something the color needs, it might not work.
            • 14725
            My colleague is trying it today, so I will let you know
            • techie0419
              • Apr 2017
              • 36
              I'm curious how it turns out as well. I can see it making a difference with boards or possibly even drums (although a black drum *should* work in both color and monochrome machine of the same series...) but the op panel only displays the information it was sent? But I have been wrong once or twice, so it may very well happen again. Eventually. ;-)
