bizhub large capacity tray paper skewing...
  • n25an
    • Jul 2008
    • 1030
    a word to the wise
    if you are getting paper skewing from the large capacity tray...
    both drawers...
    check the paper path door on the right leading from the unit...
    if you see plastic dust everywhere...
    all the rollers are shifting to one side...
    and are being sheared of plastic...
    one of the door hinges is bent...
    sure sign... the rear spring that is part of the rear hinge does not look straight...
    door skews
    paper skews
    you think its springs and stuff...
    just replace or straighten rear hinge...
    on the lct right door...
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
    • 22999
    Re: bizhub large capacity tray paper skewing...
    which bizhub?
    • n25an
      • Jul 2008
      • 1030
      bizhub c452
      • n25an
        • Jul 2008
        • 1030
        also sometimes that guide section above tray 3 and 4... the plastic gets warped... or has issues... and needs to be replaced... had that happen to me once...
        • Hansoon
          • Sep 2007
          • 3374
          ........or one of the lift cables jumped from one of the pulleys. Happened to me twice.
          Hans
          • allan
            RTFM!!
            • 5462
            Hans
            Still happens even on the 8 series...
            Whatever
            • anzew
              • Nov 2014
              • 10
              Hi guys how do I stop this from happening? Every time the customer opens the tray, the paper will slam down and cause the cable jump out of the pulley.
              • rrrohan
                • Sep 2011
                • 1977
                or the hooks on door that keep door closed are snapped
                • srvctec
                  Former KM Senior Tech
                  • Oct 2009
                  • 827
                  I've just been putting small strips of mylar on the pulleys to prevent it from happening. Done it numerous times over the years with no call backs related to that issue.
                  Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
