Konica C364e lines through ADF (trailing edge of original)
  • jonbonse
    • Jun 2009
    • 737
    Hi All
    I have Konica C364e that when copying through the ADF produces a line which turns out to be the trailing edge of the original showing up on the copy....Please see the pics...
    Is there anything I can do to blank this?
    On the Ricoh's, there used to be a user setting letting you erase by the mm....
  • copier tech
    • 8202
    Re: Konica C364e lines through ADF (trailing edge of original)
    Set up the DF correctly in CE mode & you wont get a line.
    If in doubt consult the service manual.
    • jonbonse
      • Jun 2009
      • 737
      Is CE mode Konicas name for Service Mode?
      • copier tech
        • 8202
        Yes, so you clearly are not one!
        • jonbonse
          • Jun 2009
          • 737
          Not one what??? A service mode? 😏
            (C)ustomer (E)ngineer Mode
              NO clearly not a CE.
                • 14972
                As soon as you become a service mode let us know. Lol
                • jonbonse
                  • Jun 2009
                  • 737
                  Hehe 😂
                  • jonbonse
                    • Jun 2009
                    • 737
                    Hehe 😂
                    anyways, I have found the info in the (S)ervice (M)anual so will see how I get on..😉
                    • tsbservice
                      Field tech
                      • 8053
                      Don't move the machine around pushing DF. It's not square to the main body thus you get the line.
                      Redo DF setup, like new out of a box or follow the correct procedures in SM to adjust DF.
                      • jonbonse
                        • Jun 2009
                        • 737
                          • 14972
                          These DFs will go out of adjustment just by looking at them too hard. But running the adjustments in the (S)ervice (M)anual will fix it up.
                          • floody
                            • Mar 2017
                            • 37
                            looks me to the DF is not in line correctly, loosen the screws on the hinges and adjust the DF
